Greenalleycat
- Jul 12, 2021
- 624
Hey all,
Epoxy anchors are all the rage these days and their performance seems to be getting better and better as time goes on.
One contractor that we work with does fall arrest installations and that naturally involves epoxying in M16 rods
Typically our standard spec has been 125mm as this has been the minimum allowed by the top epoxies (Hilti RE 500, Ramset C8 Xtrem etc)
Now these epoxies are allowing anchors to be embedded as shallow as 80mm in latest software iterations
Technically, these do meet our design loading requirements, although I am awaiting a response from a manufacturer about whether there are any concerns with impulse loading vs static loading
I have some concerns about the redundancy of shallow-embedded epoxy anchors - potential poor floating leading to delamination of cover concrete and so on
I've said to the contractor we are unlikely to use it for any retrofit work on old buildings due to the many unknowns, but that we will look into it for newer buildings where concrete thickness, reinforcement content, and build quality can be more confidently assessed
I'm now in that process of doing some due diligence, so I've emailed off to some tech support people at one epoxy supplier
However, I'm interested to know whether anyone else has ever used shallow embedded epoxy anchors in such an installation - any thoughts to share?
