Hi all
I am designing a lifting tool which will be used to lift a 2000kg concrete slab.
Please have a look to the screenshots below.
I need to dimension a suitable shaft for the points 1 and 2, but don't know where to start.
I guess I would need to calculate the radial load at point 2, Will it be simply 5000N (2000kg/4), or the calculation need to involve the length of the green beam as well?
I wanted to use a bronze bush to reduce the friction at the point 2, but again I don't know what to take in consideration in deciding if that material is suitable and what thickness need to be.
Thanks for any advise how to proceed.
