Sewing Solids
QShan
CA
Is there a way to sew two solids together other than Insert->Feature Operation->Sew which tells me that I "cannot sew solids into a sheet"? I started with serveral sheets, applied a thickness to them and now I want to make sure they are one solid. I can't sew them first because the thickness option doesn't work once they've been sewn together.
-Shan
Once they are thickened into solid bodies, try to Unite them rather than sew.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Thanks for the hint looslib. That works on about half of the surfaces I have. On the other half, I get error messages reading "Non-Manifold Solid" or "Internal error: Memory access violation" or Unigraphics closes on it's own. Any ideas?
-Shan
Put your maintenance dollars to work and contact GTAC.
Ben Loosli
Ingersoll-Rand
I second Ben's advice. Memory Access Violations are sure signs of either buggy software or corrupted parts.
-Derek
