charliealphabravo
Hi all,
A 4-story wood frame hotel (2 years old) is experiencing localized settlement along some shallow interior monolithic strip footings. Our working hypothesis is that the interior footings in question were constructed on about 4 feet of poorly compacted fill or possibly that there are localized problems with the natural soils. The exterior stemwall footings are about 4 feet deep and so are near natural grade. There are no indications that the exterior footings are experiencing excessive settlement and most other interior footings seem to be performing well. We have a fair set of construction plans but don't currently have access to any of the original testing reports if they exist.
As the structural investigator on the project I have some geotechnical background and am working closely with an experienced geotechnical engineer in the area to put together a testing plan. I would appreciate some additional opinions as to what tests might be informative in testing our hypothesis.
The current plan includes monitoring wells and soil sampling for laboratory density testing. We are also considering nuclear densometer testing which will need to be intelligently located and require a larger disturbed area. If the soils are not highly consolidated clays then i would like to consider some type of cone penetrometer testing through slab cores since more of them can be used and performed less intrusively.
My concerns center around the type/depth/number/location of the tests. On the interior we are working with a low overhead environment (8 ft). Also more test locations would seem to be better than fewer unless we can locate them intelligently. I think the issues are fairly intuitive but I would just like to have confidence that we are allocating our resources well and have the best chance of learning something.
Thanks in advance.
Thanks in advance.
