molerat2210
Geotechnical
I have a site with an existing fill between 4 and 17 feet thick over a firm, residual soil. The area of the existing fill is about 4 acres. I need an intelligent method for calculating long-term settlement of the existing fill layer. The fill consists of sandy elastic SILT and micaceous silty SAND. SPT N values range from 2 to 10. The fill is clean with little debris or organics. Moisture contents around 20 to 30 percent. Existing compation about 80 to 85 percent of modified proctor. No additional surcharge is proposed. Site area will be used as a cemetery. Desire to limit future ground surface distortion. I understand that any method is probably a calculated guess at future settlement behaviour.
