Setting your Working Directory
  • Thread starter Thread starter Moroso
  • Start date Start date
M
Moroso
Guest
Is there a way to set your working directory to a directory other than where the config.pro is located
Thank you
Setting the home directory:
On a windows based machine: Right click on the icon that you use to launch Pro/E and select PROPERTIES, choose the shortcut tab and change the start in to the full path of the directory where you want Pro/E to start in.
On a UNIX machine: navigate to the directory that you want to start in and give the Pro/E start up command from here.
If you're in Wildfire, just right click on the folder and set it to 'Working Directory'.
Steve C
In 2001 or WF goto File > Set Working Directory and browse to directory you want.
I always edit the batch file that starts Pro/E and change to the top level data directory just before Pro/E starts. In other words, find the loadpoint\bin\startupcommand.bat file and put in a line like:
cd G:\CAD\SOLID
You can still over ride this setting with the short cut start in property.
I also add a line to change to the trail file directory and purge that everytime Pro/E starts so that it doesn't fill up the disk with trail files.
I don't think I was clear enough, my mistake.
When Pro/E starts up initially is there a way to set your working directory automatically to a directory other than where the config.pro is located.
If my config.pro is in ex. c:/Program Files/ProE2001 and I want my start up dir to be d:/Work, I want to have Pro/E start in the d:/work directory but I don't want to have my config.pro in that directory I want it to be read from the c:/Program Files/ProE2001 .
Thank you
mgnt8's answer (first reply) is what you want...
Another method is to start Pro/E using a 'wrapper' script instead of just launching the proe2001.bat file...
proe.bat
----------8<------------
set path=c:/Program Files/ProE2001/bin;%path%
cd /d d:/work
proe2001.bat
Then use this batch file to launch Pro/E instead.
-Brian Adkins
What I needed to do was put my config.pro in the loadpoint text directory and then I can change my Start in path
Thanks for all suggestions everyone
Brian
