I'm working with a few mechanical seal vendors on a product where our customers will be specifying a variety of seals depending on the application of our machine. This machine has a nickel-plated carbon steel shaft or 316L shaft. A couple of seal vendors are proposing cartridge designs that put cup-point set screws against the shaft on journal that has the o-ring fit of the seal rotor. (They don't want to make a special rotor that extends to the journal where the cup points belong)
I am concerned that the set screw damage to the shaft will cause damage to the o-ring even if the damage is dressed well before installing the new seal. Plus if anyone decides to dismount the seal in working condition they will need a new o-ring before re-installing.
Am I worried about nothing? Or is this a major installation and reliability issue? Your thoughts and experiences are appreciated.
David
David
