set part (visual basic - solidworks)
sisau
SE
I am trying to edit a SW part using Microsoft Visual Basic. I just want to edit some dimensions. The code I am using is the following:
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
Set myDimension = Part.Parameter("dimension2@Sketch2")
myDimension.SystemValue = Excel.Range("C4") * 0.001
Set myDimension = Part.Parameter("dimension1@Sketch2")
myDimension.SystemValue = Excel.Range("C3") * 0.001
Set myDimension = Part.Parameter("dimension3@Sketch3")
myDimension.SystemValue = Excel.Range("C5") * 0.001
Part.ClearSelection2 True
boolstatus = Part.ForceRebuild3(True)
The problem I have is using "Set Part = swApp.ActiveDoc" because I can only edit an active part. This gives me 2 main problems:
- I can't edit a part that is not active/opened.
- If I open more than one part with the same name of the dimensions, all the parts are changed. (I know I could solve this just changing the names of the dimensions, but I don't want to).
What I would like to do is put some kind of reference to "set part" in order to change the part I want and not an active part.
I hope I have explained in a good way my problem... Thank you for your help!
In the API Help, look for "accessors" under ModelDoc. You can access a model by opening a file, gettiing a component, or from a list of open files, among other ways.
[bat]Honesty may be the best policy, but insanity is a better defense.[bat]
-SolidWorks API VB programming help
Thank you but I didn't find how to do it. I am a beginner using VB and I have no idea about how to use it. All I have done is copy/paste from internet, so if you could correct my code I would be really grateful.
I think you need to set up a modeldoc2 object first then set the part object equal to that. You would do this is you want to work with a drawingdoc too, it doesn't make sense to me but that is the way they show it in the help.
Like this (I usually do things the long way but you should get the idea):
Dim theModel as sldWorks.ModelDoc2
Set theModel=swApp.ActiveDoc
'' Now just set the Part object equal to theModel object
set Part=theModel
HTH,
Dan
thank you for your help. finally i solved it using the following code:
Part.Parameter("dimension1@Sketch1@Actuator1.1.Part").SystemValue = Excel.Range("C5") * 0.001
Part.Parameter("dimension2@Sketch1@Actuator1.1.Part").SystemValue = Excel.Range("C6") * 0.001
