Im just starting to investigate the technology of bolted joints and have come across the term 'set' or 'embedment'. The literature I have suggests that this phenomena, which is caused by a crushing/collapse of the contact surface asperities etc, tends to reduce preload built into the joint. It must therefore be allowed for in the initial calcs.
What puzzles me a little is that we are concerned with metals here. I didn't think that metals showed any significant tendancy to 'relax' if kept under load, as would say a polymer material. I would imagine metals to act more like the situation one would get if putting a nut and bolt through a couple of rough-sawn planks of wood. The surfaces would crush DURING the tightening process, and tightening torque would not begin to rise until this crushing process had been completed. In such a case, loss of preload due to 'set' at the time of torquing, and would therefore not need to be allowed for in the initial calcs. I do understand however that in doing the same with lumps of plastic there would be a loss of preload with time due to the visco-elastic behavior of these materials.
Clearly I must be missing something. Perhaps someone would like to relieve me of my ignorance !?
