Hi, I am new to this forum and also very new to automation. I am a mechanical engineer but the plant I work at is small and we don't have any electrical engineers. Anyway, long story short, I am looking to replace an existing air-actuated rotary gate with a servo motor setup. The problem is that I don't know a whole heck of a lot about servo motors, controllers, etc.
The gate is basically a cylinder with 4 sets of cups located 90° apart around the circumference that take dough balls from a belt and load them onto an overhead proofer. The gate receives the balls, gets a signal from a proximity switch, rotates 90° and drops the balls into the proofer trays. Acceleration is moderate, torque requirements are very small, but the accuracy is important.
I guess what I am wondering is will a servo motor and controller be a decent solution for this application and if so, is the motor and controller basically all I need or are there other components that I am overlooking? In other words, can a servo motor with a controller be used as a stand-alone device or does it require other control/power components? (we have 3-phase, 480v at the plant)
The reason we want to change the setup for this operation is that the air actuator we are using right now has been failing on a monthly basis at $2500 a unit - primarily due to poor maintenance. We are hoping a servo motor setup would provide us with much better control and negligible maintenance. Any input is appreciated - thanks
