The Designer
I tried this several times and I'm confused now.
In Etabs models with retaining walls beside the columns .. the retaining wall carries a reaction greater than weights on the floor they are connected to.
For Example a 6 floors building with a retaining wall under the first slab/floor
the reaction of the retaining wall (i mean the summation of reactions of all retaining walls joints) is 1000 tons (working load combination)
while the total working load/weight of the building is 4500 ton ...
this seems illogical ..
i made a trial amd deleted all the floors except for the first one and the reaction of the retainig wall is not 1000 ton any more ... its like 400 ton (but i can't exactly recall the exact number)
i tried this on several Etabs models with retaining walls beside the columns ..
when i delete the upper floors the reaction of the retaining wall decreases...
so my question is .. does retaining walls really carry loads from the above floors or is this an error ... and if it is an error .. what can i do about it ..
i'll appreciate all your opinions
and thanks to you all in advance
