Two Questions:
For transformer protection:
1) If I need to use series connected two fuses for transformer primary protection, can I use one fuse on the primary side and on the secondary side the other, or I must use both of them on the primary side in order to call it series connected?
2)If I need to use a current limiting fuse (CLF)for transformer secondary side bus Arc-Flash protection purposes - what location I should be using the CLF - primary side or secondary of the XFMR?
Thanks for any comments.
