Seperate charactors in string
Lliam
AU
Hello everyone,
My name is Lliam, I'm new to the forum and to VB
I do have programming experience with PICAXE Basic (PICAXE micro-controller language)
I have been able to put together a code(with a lot of help from the PICAXE guy's) that reads data sent to the serial port from the picaxe.
My next goal is to extract certain parts of data and and them to a corresponding text box.
-For example:
Output from PICAXE:
A = 10
B = 12
C = 4
D = 5031
This data is currently displayed in a single text box.
How can I then divide it so, say textboxA displays 10, textboxB displays 12, and so on...?
Thankyou in advance,
Lliam.
Look into the Split function:
Description
Returns a zero-based, one-dimensional array containing a specified number of substrings.
Syntax
Split(expression[, delimiter[, limit[, compare]]])
The Split function syntax has these named arguments:
Part Description
expression Required. String expression containing substrings and delimiters. If expression is a zero-length string(""), Split returns an empty array, that is, an array with no elements and no data.
delimiter Optional. String character used to identify substring limits. If omitted, the space character (" ") is assumed to be the delimiter. If delimiter is a zero-length string, a single-element array containing the entire expression string is returned.
limit Optional. Number of substrings to be returned; –1 indicates that all substrings are returned.
compare Optional. Numeric value indicating the kind of comparison to use when evaluating substrings. See Settings section for values.
where you would use vbLf ( Chr(10) ) as the delimiter.
Cheers,
Joerd
