btrueblood is right, cavitation shows up in the 0 to 1x range. And with water, cavitation always occurs slightly unless the NPSHa is ten times or more than the NPSHr. One must note that cavitation causes the most damage at 2x NPSHr, and slightly less, say 1.5x, will cause enough cavitation that the collapse of the bubbles are cushioned by the large amount of bubbles around it, thereby decreasing damage to the impellers. On the other hand, more than 2x causes a decrease in cavitation resulting in less damage. On another note you can always look at the pump curve vs. the system curve and try to get the pump running right in the best efficiency point, or where the 2 curves intersect. The closer you can get to the BEP, the less cavitation you'll get and your pump will run much more efficiently.
agmotes
