Richard85ZXT
Automotive
I have a first generation Nissan 300ZX with Rear Semi Trailing Arm suspension. While many cars of this time used this type of suspension, especially European and Japanese manufacturers, they appear to be very outdated. I may in the end swap to an alternate suspension entirely, but since I have a couple, and one is a daily driver, is there any hope for the STA? Most of the guys with these cars don't take the time to understand suspensions, and while I am WAY behind many of you I have found myself almost too far ahead of many other enthusiasts and in need of understanding and help on many areas. General thought on these cars is that stiffer springs/dampers, lowering, poly bushings, wider tires and maybe stiffer roll bars is the extent of handling abilities with the STA. While Simply trying to find out the best way to find the CG so I can attain a proper Roll Center most the community was confused as to what I was doing and a couple even said, it doesn't matter where it is, lower CG is better, so just lower the car. One member, who rarely is on posted up this site, thankfully, and I have been reading and learning. While I know I have a lot more to learn, I thought I'd simply try to find out is it worth while to try and adapt a STA rear suspension for occasional track use while maintaining the comfort of a daily driver? I am in an area where the roads are rough so stiffening the entire suspension would be a death sentence, and by being a STA any lowering makes Negative Camber excessive. I am sorry for the long winded post and lack of technical speak, but I am still learning, and started reading a couple of the books in the FAQ section, but until I put it into practical use I feel it'll seem a jumble. Thank you all for taking the time to explain in depth and share your knowledge with those of us still learning, I truly do appreciate it.
