marcleblanc12
Has anyone ever tried to solve for reaction loads on a semi trailer that has tandem axles? I've been treating it as a statically indeterminate beam to get my 3 reactions (at the kingpin and each of the axles).
I've been solving this using Clapeyron's theorem (3 moment equation) and I keep getting a very high value for one axle and a negative value on the second axle.
Here's what I'm basically trying to solve:
A trailer 45 ft long loaded with 80,000 lbs evenly distributed over the entire length. The trailer has two tandem axles spaced 5 ft apart at the back and a kingpin at the front. Using the 3 moment equation I get a reaction of 25,940 lbs at the kingpin (seems normal) but then I get 96,234 lbs at the first axle (more than the weight of the trailer) and then -44,294 lbs at the rear axle (a negative number).
This may work out mathematically, but in reality I know that these loads on the tandem axles are not the case. Has anyone else come across this before? I've tried solving this using a few different methods and still arrive at the same thing. I've done other statically indeterminate beams that have worked out to reasonable loads, but for some reason when I try to do these trailers with multiple axles close together, the reaction loads seem very odd. I've tried this on trailers with 2, 3 and even 4 axles and it still gives me the same weird results.
It seems that when I add up the reactions from the tandem axles and divide by two I get 25,970 lbs per axle (for this example), which seems closer to what I should be getting although I'm sure they're not equal. Let me know if any of you have come across this situation and figured out how to solve it.
