I am designing a semi integral bridge in the UK. It is a 2 span bridge (both spans approx 30m), with fixed bearings at the central pier and free bearings at the abutments to allow for expansion.
The deck is continuous steel plate girder with a RC deck slab. At the ends of the bridge the deck continues round the ends of the girders to form an end screen wall (i.e. the ends of the girders are protected by a continuation of the deck, perpendicular to the carriageway surface above.)
This end screen wall projects about 2-2.5m into the embankment, so it will retain some earth and will therefoe be subjected to associated earth pressures. I'm also concerned about the forces on the wall from thermal expansion of the plate girders.
Does anyone have experiance designing a similar detail?
