Jan 22, 2012 #1 JAG11512 Mechanical Joined Jan 21, 2012 Messages 7 Location US How do I determine the slope of a self supported cone roof? Will it always be 2" in 12" or can it be different?
Jan 22, 2012 #2 IFRs Petroleum Joined Nov 22, 2002 Messages 4,680 Location US It can be different and almost always is. Shallower slopes have thicker plates. You have to use good engineering judgement. Upvote 0 Downvote
Jan 22, 2012 Thread starter #3 JAG11512 Mechanical Joined Jan 21, 2012 Messages 7 Location US Do you know of any books that go in depth on Storage tank roof designs? Thanks. Upvote 0 Downvote
Jan 22, 2012 #4 JStephen Mechanical Joined Aug 25, 2004 Messages 8,732 Location US API-650 includes a section for calculating thickness of self-supporting roofs; you work through it backwards to find the minimum slope. Note that API-12D, 12F, and UL-142 all have different slope requirements from API-650. Upvote 0 Downvote
Jan 23, 2012 #5 LCeballos Mechanical Joined Jan 19, 2012 Messages 29 Location US I am agree with IFRs and JStepehen. Paragraph 5.10.5.1 says: "Self-supporting cone roofs shall conform to the following requirements: theta <= 37 degrees (slope = 9:12) theta >= 9.5 degrees (slope = 2:12)" Regards. Upvote 0 Downvote
Jan 23, 2012 Thread starter #6 JAG11512 Mechanical Joined Jan 21, 2012 Messages 7 Location US Would this be the same for a tank thats 19ft dia. and 32ft high? If 2:12 is acceptable for this tank than thats what i would like to use. Upvote 0 Downvote
Jan 23, 2012 #7 IFRs Petroleum Joined Nov 22, 2002 Messages 4,680 Location US Depends on the thickness but I think you can stay under 1/2" (API max). Run the calcs and see! Upvote 0 Downvote
Jan 23, 2012 #8 Duwe6 Industrial Joined Jul 27, 2010 Messages 2,189 Location US 2:12 at 19-ft should be in the neighborhood of 3/16 to 1/4" roof thickness. Upvote 0 Downvote
Jan 23, 2012 #9 IFRs Petroleum Joined Nov 22, 2002 Messages 4,680 Location US Depends on the loads but in general I'd agree that 3/16 to 1/4 would ordinarily do it for you. Upvote 0 Downvote
