I've been looking into a self-locking taper connection. My ideal outcome is 'slightly' locking so therefore I've dug up the formulas.
The math that predicts that a taper locks when it has more frictional force than reaction force, i.e. (half-angle of the taper) = arctan(coefficient of friction).
The other agreed nugget is that well-machined or ground steel tapers begin to lock when the half-angle is at or shallower than 7 degrees. (
Combining them, the 7° rule of thumb corresponds to a frictional coefficient of .123.
Book friction values for dry steel vs. steel range from .4 to .8. Less than 0.13 would require grease or high polishing. It's well known that steel tapers should not be greased unless you want them permanently fused or you're asking for the hub to burst.
Can anyone shed light on this discrepancy?
