Selection of valves in Industrial Reverse osmosis plant
Mac111
CA
In reverse osmosis pre-treatment (after FRP Multimedia Filter and before the Feed Pump) the
type of valve used is "Electrically actuated butterfly valve".
For Chemical cleaning line (CIP - Claening In Place), the type of valve used is "manually
operated Ball Valve".
Basically the purpose of these two valves is "ON/OFF" not to control the flow OR pressure.
Can anyone explain, if the purpose of these valves is same, why different types are being
used?
Mac
Butterfly valves are excellent in terms of price and cost of ownership; they weight fas, far less than ball valves (or gate, globe or check valves) in the same diameter/pressure class, and if your intention is to ensure on/off, and don't have much pressure and won't want to regulate the flow, the butterfly valve option is an excellent one.
The comparison manual ball valve vs. actuated butterfly valve, though, doesn't make any sense, since manual vs. actuation are two very different roads.
My focus is on valve stockists in the us and uk who supply duplex and super duplex valves, and inconel and hastelloy valves, plus titanium, alloy 20 and 904L valves.
