Selection of many surfaces in pro/m
  • Thread starter Thread starter akonrad
  • Start date Start date
A
akonrad
Guest
Hi
How do I select hundreeds surfaces for applying load, when they are inside a lump? Is there a way to select all the surfaces of the body, and then deselect some from them? Or select with a box everything, even the inside/hidden surfaces?
Konrad
akonrad,
you use the surf and bound function. Pick the start surface then in the reference box change from individual to Boundary and pick your bounding surfs.
Krow72
Edited by: krow72
Krow,
Actually it now began to work without "boundary" option. I don't know why I couldn't select by window earlier. And now "boundary" doesnt't seem to select anything, regardless whether I click or try to select by window, nothing gets picked. Looks like an early bug in F000.
Thanks anyway
Konrad
