GeotechRic
Geotechnical
Here is the situation, due to the project requirements I need an expansion board that is flexible and excellent as a water seal. The board would be used for an expansion joint between a concrete wall and a wall cap in order to prevent water from infiltrating behind the wall and freezing and thereby creating problems. Basically we need something better than typical wood/plastic expansion boards. Any suggestions?
Also what would be the procedure to install these? Would a sealant be also needed on top of the board to ensure a better seal?
