Ok for a short understanding of this job, it is an existing building, 23' to top of storage, 30' to peak. Now ESFR sprinkler will not work do to the massive amount of ductwork above and the fact that you are limited to moving around ESFR sprinkler to avoid obstructions. So I am left with CMSA or CMDA sprinklers.
The storage is plastic pallets with plastic bins that are not covered or encapsulated and stored in racks against the walls. With the issue of the ductwork I have chosen to select the density area method. So I have chosen based off table 16.2.1.3.2 storage over 22' to 25' max, commodity class 1, not encapsulated, 4' isles, no mandatory in rack sprinklers (the customer doesn't want them),used curves F & H, also apply figure 16.2.1.3.4.1 which says sprinkler density vs storage height.
I have no clue how to apply that last chart to my calc, also I am wanting to make sure I am on the right path. I have never done a system in a longgggggggggg time that was this choosy.
I can start to select my pump, but I want to make sure I am on the right path to selecting the design that I exactly need.
Any help is greatly appreciated.
