ugandabob
- Jul 27, 2006
- 27
Question regarding foundation design for earthquakes. A clause in the Canadian code requires foundations to resist the overturning capacity of the SFRS, not the applied loads only. (The idea is to avoid having the foundation be the yielding element in the event of higher-than-expected seismic forces.)
I am looking for guidance for tension-compression braced frames.
Should the overturning capacity of the SFRS be based on the load at which the compression brace buckles, or should it be based on the capacity of the single brace in tension (often higher)? For Conventional Construction (Rd=1.5; Ro=1.3), the steel design code does not require redistribution of the post-buckling compression forces for the design of the steel structure. But the overturning capacity may be much larger when considered as tension-only.
If the overturning capacity is based on the buckling load, it seems that foundation could have issues if the seismic forces are larger than expected.
Thank you
Thank you
