Found out this is the only forum where structural engineers are active.
Here is the one-story CMU wall structure. The base shear is always being considered as summing up the roof weight + upper half of the wall weight. When it comes to design the adequate of the shear friction between the bottom of the shear wall and the top of the foundation, do you still use the same base shear for the shear friction demand, or you will add the lower half of the wall weight on top of the base shear?
