termoguven
ASME Sec VIII, UG53 instruct Ligament efficiency determination.
I try to design a collector pipe (D:273mm) with drilled holes
(similar to figure UG-53.1)
24 holes with (d:50mm, p:89mm)
and 2 rows of holes,
distance between two adjacent rows:65mm
As per UG-53(c), can you tell me steps to determine circumferential ligament?
second question:
65mm is distance from top view of rows,
can I consider the distance as "Arc Length" on Collector pipe? (to determine circumferential ligament)
second question:
