sheafromme
A stepper motor with a 5mm shaft was specced and passed along to me to affix a 14-tooth pulley to. The motor has a flat machined on the shaft and is clearly set up for a setscrew-style attachment. Additionally, the pulleys in the correct sizing also use setscrews. This is a problem because although I am familiar with design fundamentals for keyed shafts, clamping shaft collars, and other similar methods of securing components onto shafts, I have never worked with setscrews in this application. I am having trouble finding any literature on the design of setscrew couplings beyond just disparaging articles or passing references in textbooks to a torque spec. The pulley will be driven back and forth rapidly and is a critical component for the larger system so I would not feel comfortable just affixing it with any old setscrew and without a proper design process to prove that the connection is adequate.
Essentially, what I am asking is
- Is there any literature for proper design of setscrew shaft attachments that I am just missing?
- Do you have any suggestions or input on best practices for such an application?
Thank you!
Thank you!
