Section Cut Transfer (drafting To Catpart)
  • Thread starter Thread starter giumel
  • Start date Start date
G
giumel
Guest
How can I Copy the section cut J-J in the CATPart linked
to CatDrawing?
The main problem is :
In the Catpart a SKETCH is created and this could be OK,
but the positon is always in the XY PLANE!!! Y=0
I need it in the right 3D plane as in V4!
PS I am using V5R16
Make a new section view...
Don't copy the section. Make a new one from the plane you used to make the original skect.
CADMiester
Tank's for the answer, but I think my problem was not so clear.
I will try to explain more in detail.
I DISCOVERED TONIGHT (ITALY) THAT:
The COPY is possible only with isolated view
1) The sketch is automatically created in the CATPart when
you isolate the section cut J-J and THEN copy IT in the CATPart.
V5 CREATE ALWAYS A SKETCH IN THE CATPART when you
perform this kind of operation.
The origin of the section will be the origin of the Absolut axis Sistem.
what is wrong is the position in the catpart.
I will try now how to have the exact position of the sketch
have a good day
GIUMEL
