Artemetra
- Jun 6, 2011
- 3
Hello folks, I'm trying to save on some weldments in a structure. In fact, the structure has 38 elements X 5 units X 6 welds per element = 1140 welds! A steel disk is welded 3/8" away from a plate with a port hole, on 3 nuts used as spacers. Welder must tack the nut in place then the disk. 190 disks makes for welders going postal.
What we need is a pop-in stand-off or something. Since the plate and disks are CNC plasma cut, no problem to make extra holes. Holes are 7/16" so 3/8" to 1/2" would work. Plates are all 1/4". Solution is mild cyanide (1%), mostly water - but maybe a thin metal clip would work. I'd love to find a plastic stud with mushroom head that would pop into the holes, then accept the disk.
