Searching for High RPM Vertical Machining Centers
NoelD
3
We machine bronze and soft steel (1008/1010) with small ballnose and regular endmills. The tool sizes are continually getting smaller. Currently our smallest is .0354" in diameter. I am looking for a machining center that offers a high spindle RPM (35,000 - 40,000) as well as high feeds and rapids without compromising reliability with minimum upkeep. We currently are using a HOWA machining center which we are very happy with, but they do not offer RPM's over 20,000. I am looking for any suggestions or even names of machine builders that I may research that would offer what I am looking for.
How about an aftermarket spindle to fit as one of the tools in the machine you're already happy with???
Lots of vendors, lots of ways to drive it. Some double or triple your machine's spindle speed. Some are electric. Some are air.
Watch end play and bearing float for what you really need, and spend some time looking.
Chances are that any machine you'd buy would have one of these companies spindles installed in it anyway.
WATCH OUT FOR THE COST OF COLLETS ! THE COST OF THE TOOL HOLDERS FOR SOME OF THESE SPINDLES WILL NUMB YOU. Check that out BEFORE you buy!!! $300 to $800 for a tiny collet !!! It's truly sick, but I'm NOT joking!
Larry
look at boston digital, they build an excellent machine we used it to cut graphite at break neck speeds and it had a 40000 rpm spindle. it was a great machine considering ours was a prototype.
Do you have a contact (phone #) for them. I only find a LLC that does software under Boston Digital.
Nevermind, Boston Digital is part of Mikron and I have contacted them.
Rego fix makes a very good spindal speeder to fit your machine---it is a 5/1 ratio up to 40,000 RPM and costs about 5 grand.---if you are lucky you may even be able to do tool changes with it.
Don´t forgote If you have high speed (RPM) you need high feed. Good Luck Libor Pírko
