Searching for Components
SaturnVI
16
Greetings:
I've been asked to find a Compact Flash socket/header for a product my company is developing. Specifically, it needs to be Reverse keyed, type 2 compatible, fairly shallow (there will be no ejector mechanism) and RoHS compliant. I've checked Mouser, Digikey and most of the big manufacturers but can't seam to find a part that fits all of these requirements. Does anyone know where else I can look? Thanks in Advance.
You can try Molex and Tyco(AMP). The hard part will be the RoHS compliance as connector vendors are scrambling to find suitable plastics that will withstand the 260 degrees needed during the PCB assembly process. Also try
I hope this helps
