I have a sedan based car that I am designing an underfloor for aero setup for. The car is used for Hillclimbs and Sprints so the rules are fairly open.
I was starting the floor with a front splitter. The top of the splitter will be at 0 degrees AOA and the under-splitter surface will taper down on an angle of about 15 degrees to create the underfloor throat. I'm a bit limited to ground clearance as some of the tracks I run on have steep inclines so I'm hoping to start the inlet at about 100mm and have the under car clearance at about 75mm.
I was going to make the downforce generating section about 750mm wide and centrally mounted. It will terminate with a diffuser.
I was going to use continuous length 'spray suppression brush' that trucks use on the guards in an attempt to 'seal' the underfloor along it's longitudinal edges.
The areas between the tunnel and the outer body will still be smoothed, but will not produce downforce. Their only function will be to mount some fences behind the front and rear wheels to guide the high pressure wheel arch air out from under the car.
I have done some reading on wingtip vortices as I thought I could produce a vortice just behind the front wheels and use it to also help seal the floor.
I was intending to mount a small wing tip just behind the front wheels (maybe sticking out 25cm to get out of the boundary air)
I was hoping to generate a wingtip vortice along the length of the car -
Is there a better way to create a controllable vortice?
