All:
I would remind everyone interested in this subject about what we "pioneers" learned about the miracle of Teflon when we started to use it in the 1960's: it's a panacea that all engineers should be warned about.
Like other, so-called engineered miracles such as Stainless Steel, the silicones, Freons, etc. there are inherent trade-offs that must be considered. Once again, the Universal Engineering Law prevails: There are no free lunches or rides.
Back in 1965 we found out that, yes, Teflon is totally inert to some of the Cosmos' worst bad actors (such as Phosgene); however, this comes at a price of a mechanical Achille's Heel: it has a rotten, stinking memory! Without proven purity and proper re-inforcement (such as with glass fibers), Teflon will draw-out under sustained stress and not return to its original shape. It has no memory; as a potential gasket material that we originally envisioned, it is a total failure. It's sad, but true. But for experienced and scarred old engineers, it's a story that has been repeated many times in engineering history: all that shines is not gold. Beware of any substance or gadget that is claimed to solve all your problems at a cheap price, without any brain cell activity, faster than anything you imagined, and available on the spot. It is not common sense to believe that this is possible.
moltenmetal is right on target with his inference that Phosgene should be treated on its own terms of a bad reputation as a lethal substance. Nothing should be spared in considering its containment and control. There exist specific and detailed instructions and directions on how to deal with this extremely bad actor. One should not generalize nor experiment with this application.
My main point is: don't concentrate on the chemical properties of the containment material simply because of the lethal nature of the substance and the perceived "inertness" of some materials. The total mechanical design is just as (or more) important than the process design. This is a made-to-order situation where Mechanical and Chemical Engineers should be both deeply involved in the design of any containment or transport system for handling Phosgene. Mechanical integrity should not be compromised because there is no allowance for mistakes.
Art Montemayor
Spring, TX
