Looking for a little advice for gaining strength in a sea water (salt water) environment.
Presently using 316SS (no passivation) on a vertical post 1/2" diameter threaded in at the bottom with shoulder stop. Part is breaking above shoulder with large fillet applied. I know I need to at least passivate since I think corrosion is pitting away and weaking the part at stress points. I am also think to change to 17-4H1150 to increase yeild strength, but am a little concerned about corrosion and wanted to know if other options may be available. I believe toughness is an issue.
Part may be dry, wet or cycle between the two. Rod is being use to hold an oar assembly.
Thanks for you feedback and ideas.
Kind Regards,
MECOMAN
Kind Regards,
MECOMAN
