SE 14 Angular Dimension
geo12
CA
How to dimension a counterbore depth which is at an angle to the original block. The dimension should be at an angle to the top surface and perpenticular to the axis of the hole and counterbore.
When I click on both the dimension ponts,it is showing only parallel dimensions to the block.
Any suggestions please..
Before or after clicking the second element, press 'a' to toggle from linear to angular dimensioning. (I'm assuming that you're using Smart Dimension.)
