script files 2
yvonne
Industrial
GB
How do I save a script file after I make it
When I make one do i put the .scr name in the title of the drawing if so where do I save it to
I keep getting cant find file when I try to run the .scr file
Save it as file.SCR , it is a TXT file with other extension that shall be xxxx.scr.
Pardal
I make a file in word or excel and save as *.txt. Then I rename (W-Explorer) the file in *.scr. -> execute the script in AC
Lothar
Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
ACAD 2002, ADT 3.3,
OCÈ 5200
Depending on the length and complexity of the script file, you can create a customized tool bar button to execute the script file (macro), or create the file in an ASCII editor and save it with a .scr extension and load it by typing script.
Yes -
To your 1st question.
(Do I save the file with an extension "*.SCR"?)
Anywhere you want -
To the next question
(Where do I save it?)
As for running it ....
Go to the pull down "TOOLS" > "RUN SCRIPT"
This should pull up a browser ....
Then just point to it .... highlight it ... and run it.
If it doesn't run ...
Are you somehow associating the script to a "BUTTON"?
Or What?
