Howdie.
I have a problem with a particular model and wondered if anyone else has had this come up.
I have a set of screw threads in an existing file. When I try to import these threads into another file as a cut, only the core cylinder of the import actually cuts, not the threads.
I have tried different methods:
1. Insert > Shared Data > CopyGeom, then I go into Legacy mode to cut using quilt. Only the core cylinder actually cuts. I also get the message, "WARNING: Design intent is unclear. Use "Info"/"Geom Check" menu for details." So I do the Geom Check dance, and get the message, "The system could not construct the intersection of the part and feature. Recommended actions: Redefine the feature so that it intersects the part." The problem here is, I could spend literally hours trying out different methods to fix the threads to no avail. And, the threads are heavily dependent on Relations, since I use a default thread that gets modified to the specs I need for a particular job. Is there another quick solution to this dilemma?
The other method I try is:
2. In legacy mode, Feature > Create > Cut > Advanced, and I use the "From File" method. Since only iBL, IGES and VDA are allowed as imports, I try each (having exported these file types earlier). What I get instead is a message stating:
"Line 1: Can not identify keyword", and the operation fails.
Thanks for any advice you can offer,
treddie
treddie
