I am currently checking the following design:
A wood panel wall system using a Monarch M375 Z-Clip system ( where the continuous track is going to be screwed through a piece of 5/8" gyp. board to a 20GA furring channel that is running horizontally between 18GA studs @ 16" O.C.
My concern is the crushing of the gyp. board due to bearing as well as the bending in the screw due to the 5/8" stand-off. The gyp. is there for acoustical purposes and I've already been turned down when requesting that it be replaced with plywood.
Does anyone have any suggestions on how to determine the loading capacity or the gyp. or the bending capacity of a #8 screw?
Any help would be appreciate, thanks.
