Screw Feeder Experience with Limestone Dust
ldeem
258
I am working on a project to relocate a truck loading chute about 20' from its current position under a storage bin. The client suggested a rotary airlock to screw conveyor to truck loading chute. After looking at screw conveyors I was thinking of screw feeder (eliminate rotary air lock)to truck loading chute. The material is limestone dust.
I talked with a sales engineer who seemed confident the screw feeder would work. I was doing more research online I find very few companies make screw feeders.
Does anyone have experience with long term durability of screw feeders? The initial cost of the two options is the same so the advantage for screw feeder is having one less piece of equipment to maintain.
Larry
You may be able to find more sources by searching on 'farm augers' - very commonly used for moving bulk agricultural solids. (Also a dangerous piece of equipment, I might add, if not used with caution.)
Farm Augers would probably be rather light weight for this usage....... talk to the concrete batch plant guys who move millions of tons of cement every year with their augers
