I was called to work on a screw conveyor that is sagging. I have very little experience in working with them, so any help is appreciated. The auger is made from what looks to be heavy wall pipe, about 10" dia, and about 20' long. There are no supports in the middle, just one on each end. The trough is an asme pressure jacket as steam is injected into it, and is only supported at the ends as well.
The auger is digging into the trough and causing some bad galling. The galling is happening not in the middle so much, but heavily between the middle and the supports, so about 1/3 of the way in from the supports.
I am just trying to see if anyone has any suggestions on what could be done to remedy the problem. Since the auger is not scraping in the middle could that be a sign that the trough itself is sagging? or could the auger be sagging as well. We are still in the process of figuring things out, I was thinking of pulling a string across the trough to see if it was indeed the trough or the auger. any other sort of methods? How about for checking straightness of the auger? We were thinking of a dial indicator, but we could only get so far as the flights would knock it off.
Well any help is appreciated.
Thank you
Dan
Thank you
Dan
