i have developed and patented a dual surface scraped heat exchanger especially designed for high viscous liquids.
The flow annulus can be as little 4-5 mm wide and instead of turning the inner cylinder 360° it reciprocate 90° back and forth pushing the product in and out between the longitudinal scrapers(4 on each surface) mounted in grooves on the inner and outer surface. This prevents the product from being transported around the anulus in a laminar flow pattern and instead introduces turbulence to the product as it flow through the heat exchanger.
The machine is being tested at the technical university of denmark this summer along wiht a larger system that allows the product to be pushed back and forth through the heat exchanger and a mixer head. We have up to 35 bar pressure to force the product through the system and can thus handle products with very high viscousit
we are looking for ideas of products to test.
thank you
einar dyhr
deltaprocess engineering
thank you
einar dyhr
