4
- #1
I can't remember where I found this! But thought it would be fitting since it's graduation time and a new crop of engineers will be starting careers.
Alex C. Scordelis, Professor emeritus of Civil Engineering, UC Berkeley.
Based on my experience as an old teacher and engineer, I would like to take the privilege of giving the graduates some random words of advice. Keep your ears open. I may ask you questions after the ceremony is over.
1.You got a good education. Use it, and remember your fundamentals.
2.The location of the decimal point is important in the real world.
3.You no longer get 9 out of 10 points for the right method but the wrong answer.
4.Your reputation follows you wherever you go. Do a good job.
5.Learn from your mistakes – but don’t repeat them.
6.If it doesn’t look right, it probably isn’t right.
7.Try to understand the big picture and the costs, as well your own part, of each project.
8.Make sure that whatever you design can be built or produced.
9.At the end of a project, always ask yourself, “How could I do it differently and better next time?”
10.Don’t make an engineering decision on something you don’t understand or don’t know anything about.
11.Don’t believe your boss is always right – but don’t tell the boss that you are smarter then he or she is.
12.Use your common sense to check results. If you don’t have common sense, you’d better develop some.
13.Exercise your body as well as your mind, regularly.
14.There is more to life than engineering – have some fun.
15.Money isn’t everything, but it helps.
16.And finally, always remember your alma mater. You are a Berkeley engineer. It’s all out there waiting for you.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
Heckler
o
_`\(,_
(_)/ (_)
