stuart cox
- Aug 4, 2020
- 3
Hi all,
I'm hoping someone can help! I have built a Hydraulic scissor lift table for my motorcycles. I need to work out how much weight the hydraulic pump needs to be able to lift.
The table will be lifting up to around 500kg. The scissor arms are 875mm long from the scissor pivot. The hydraulic ram connected to the scissor arm 405mm from the scissor pivot point. The ram sits at an angle of 7° from floor level when the table is at its lowered point.
As the load on the pump will be at its strongest when the ram starts to lift the table, thats the calculation I need to work out how much weight the pump/ram will be trying to push at that point?
Any help would be much appreciated!
Stuart
Stuart
