655321
- Dec 21, 2006
- 66
On private commercial project, say a school campus, where the water lines are privately owned and maintained:
Would you spec out 4" pvc domestic supply waterline as schedule 40/80 or would you use a C900 (PC-???) pipe? Is there an advantage at this size to one over the other, fittings, gasket joints vs glue, etc.
Also about pressure rating, what's typical for service lines? I've seen clear criteria for public mains (which varies, some cities want all the public mains DIP PC350, others are less worried about it). But there's not much guidance I found for private services lines. Does the plumbing code indicate a minimum pressure class?
Thanks in advance for our help.
