I've been asked to evaluate a panel for SCCR labeling. The panel is fed from a 575V source. The 575V source feeds some 600V equipment, leaves the panel to an external 50kVA 575/480V transformer, then the 480V circuit comes back into the same panel and feeds 480V equipment.
So, how do I label this panel for SCCR? Should the panel be labeled for each voltage separately? The external transformer is not attached to the panel and its selection is not under control of the panel fabricator.
Thanks.
Thanks.
