pennstateie-
Good post.
IFRS-
Insert the title block onto the paper-space sheet (tab) at 1:1, no matter what size t-block (A-sz,B-sz,C-sz,D-sz...). Usual insertion is 0,0, but you might want to adjust that alittle for plotting the info line along the left edge of your print. I leave it a 0,0 and adjust the plot itself, but usually "centering" the plot and PLOTTING TO FIT solves everything. Make any viewport you want for developing your various view(s), and zoom each to a scale that corresponds to a "drawing scale" (1/2"=1'...). Plot your drawing at 1:1, and set it to "fit", and you'll be OK. If you need exact scale, find out exactly what the printer boundary is, (usually 1/4" to 1/2" off eatch edge), set your title block to a ratio of that (corner-tocorner), and that ratio will give your exact plot scale to input. If you need more clarification, take this as far as you can, and post back here with some detail, and we can take you farther forward, 'til you hit your goal. Still, this should be snough clues to get you started, anyway.
Good luck,
C. Fee
