P205
- Mar 2, 2008
- 136
I have been retained to produce erection drawings for scaffolding that is over 50 ft tall for a contractor and I'm wondering if there are design guides and/or regulations for the design of the lateral system (wind). I'm not concerned with the gravity side of things, it's more the tension due to wind loads that I'm concerned about.
Detail:
- Masonry repair work on side of 55 ft brick building
- Repair work, so no large loads due to stacking brick
- Scaffold structure will be tarpped over, therefore wind loads
- Walk-through frame system
This is what I'm thinking:
1) Determine wind loads as per Fig. I-8 of structural commentary (wind loads on wall elements).
2) Determine number of tension ties to the existing building are required based on factored wind loads over tributary area of lag shield anchor.
Detail:
