saving a assembly model as a dumb part 1
robinski
How can I save a large assembly model as 1 part so that
all internal features are not avialable for any one to see or use for reverse engineering.
I have recieved assembled models that say they are imported
and and have utilized them in other assemblies and would like to do the same with my asssembly.
Open assembly
Select:
Insert>Component>New Part...
(give the part a name, and select a Front plane)
The part should now be in edit mode within the assembly.
Select:
Insert>Features>Join...
(select the Assy components to join)
Exit Part Edit mode
for more info:
type:
joined parts, create
in the help file under index
Good Luck ;-)
When dealing with computers, there are 10 things you need to know: one, zero, and the rest is Binary.
-Josh S
NOTE: All parts must be touching (NO GAPS) in pre-2003 releases
(maybe even in 2003(?))
-Josh S
File\Save as\ - Change save as type to - Part
You have 3 choices from there on how you can save it. See help on details.
Scott Baugh, CSWP [borg2]
faq731-376
Scott,
What version of SolidWorks implemented that feature?
It is not a choice in the Save As dialog in 2001+
(at least not on my pc)
Thanks,
Josh
-Josh S
Yeah, I have 2003 at home but rarely use it...
My company has to 'Approve' the new releases before we can use them...
Some areas use large assemblies, such as tracter/trailers w/ pumps on the back of them, that require a stabile platform to open with...
There seemed to be some bugs in 2003, so now they are evaluating 2004...
(It's not my choice ;-))
-Josh S
