' Save Drawing as PDF and DXF
' SaveDwgAsPDF.swp - Original functional code by Lee Bell on 02/10/02.
' Modified for SolidWorks 2006 by JB on 3/31/06.
' Modified by Matthew Lorono ([URL unfurl="true"]http://sw.fcsuper.com)[/URL] on 4/24/06.
' Copyright 2006, 2007
' Modified by Dustin Biber on 11/11/2008
' Based on publically available information found at:
' [URL unfurl="true"]http://www.eng-tips.com/viewthread.cfm?qid=151087[/URL]
' Contact: fcsuper@aol.com (Matthew Lorono)
' This macro is provided as is. No claims, support, refund, safety net, or
' warranties are expressed or implied. By using this macro and/or its code in
' any way whatsoever, the user and any entities which the user represents,
' agree to hold the authors free of any and all liability. Free distribution
' and use of this code in other free works is welcome. If any portion of
' this code is used in other works, credit to the authors must be placed in
' that work within a user viewable location (e.g., macro header). All other
' forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
' without the expressed written consent by the authors. Use at your own risk!
' Description:
' Saves the active drawing or current view of a model or assembly as a PDF and DXF to a specified directory.
' Version - By Matthew Lorono, Copyright 2006
' 1.00 * Created Macro from various sources at the above
' website.
' * Added error handling for no docs loaded.
' * Modified error handling for failed save.
' * Added/modified comments.
' * Cleaned up user interface.
' 1.10 * Add nondrawing support
' * Add error handling for missing directory
' 1.20 * Add error handling for missing document path
' * Add user input/confirmation of save folder
' 1.21 * Expand header to prohibit money based distribution
' (such as for-profit or fee based) of this macro.
' 1.22 * Add save status to lower left status bar pane; some
' clean up; add detail to description.
' 1.23 * Added DXF functionality.
Option Explicit
Dim SwApp As SldWorks.SldWorks
Dim Model As SldWorks.ModelDoc2
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportPDFData As SldWorks.ExportPdfData
Dim MyPathPDF, MyPathDWG, ModName, NewNamePDF, NewNameDWG As String
Dim Rev As String
Dim dPathName As String
'Dim MyPathConfPDF, MyPathConfDWG As String
Dim fso As Object
Dim MBpdf, MBdwg As Boolean
Dim Errs As Long
Dim Warnings As Long
Dim swFrame As SldWorks.Frame
Dim Sheet1, FlatPatternSheet As String
Dim strSheetName(4) As String
Dim varSheetName As Variant
Dim i As Long
Sub main()
Set SwApp = Application.SldWorks
SwApp.Visible = True
Set Model = SwApp.ActiveDoc
Set swFrame = SwApp.Frame
Set swModelDocExt = Model.Extension
Set swExportPDFData = SwApp.GetExportFileData(1)
' Names of the sheets
'strSheetName(0) = "Sheet1"
'strSheetName(1) = "Sheet2"
' strSheetName(2) = "Sheet3"
' strSheetName(3) = "Sheet4"
'varSheetName = strSheetName
' Error handler for no document loaded
If Model Is Nothing Then MsgBox "No document loaded!", vbCritical: End
' Use one of the three following options for PDF save location
' Comment out the options with are not used.
' Option 1: Use the current directory
' MyPath = CurDir
' Option 2: Specify the directory you want to use
'MyPathPDF = "D:\_DesignFiles\SolidWorks\Temp"
'MyPathDWG = "D:\_DesignFiles\SolidWorks\Temp"
'MyPathPDF = "N:\Engineering\Public\Drawings"
'MyPathDWG = "N:\Engineering\Public\CAM"
' Option 3: Use the drawing folder
MyPathPDF = Left(Model.GetPathName, InStrRev(Model.GetPathName, "\") - 1)
'MyPathDWG = Left(Model.GetPathName, InStrRev(Model.GetPathName, "\") - 1)
' Call correct sub
If Model.GetType <> 3 Then Call notdrawing
Call ifdrawing
End Sub
Sub notdrawing()
' Get documnet save path
dPathName = Model.GetPathName()
' Error handler if no save path
If ("" = dPathName) Then MsgBox ("This document has not been saved yet"), vbCritical: End
' Set PDF file name
ModName = Left(Model.GetTitle, InStrRev(Model.GetTitle, ".") - 1)
Call alldoc
End Sub
Sub ifdrawing()
' Set PDF file name
Rev = Model.CustomInfo2("", "Revision")
Sheet1 = Model.ActivateSheet("Sheet1")
ModName = Left(Model.GetTitle, InStrRev(Model.GetTitle, " Sheet") - 3) + "_Rev" + Rev
Call alldoc
End Sub
Sub alldoc()
' See PDF and DXF file name with extention .pdf or .dwg
NewNamePDF = ModName & ".pdf"
' Get path and user confirmation
'MyPathConfPDF = InputBox("By Matthew Lorono" & Chr(13) & Chr(13) & "No notification will occur for " & Chr(13) & "successful PDF creation." & Chr(13) & Chr(13) & "Save " & NewNamePDF & " to:", "Confirm PDF Save Path", MyPathPDF)
'MyPathConfPDF = MyPathPDF & "\" & NewNamePDF
'If MyPathConfPDF = "" Then MsgBox "Save As PDF cancelled by user.", vbInformation: End
'MyPathConfDWG = InputBox("By Matthew Lorono" & Chr(13) & Chr(13) & "No notification will occur for " & Chr(13) & "successful DXF creation." & Chr(13) & Chr(13) & "Save " & NewNameDXF & " to:", "Confirm DXF Save Path", MyPathDXF)
'MyPathConfDWG = MyPathDWG & "\" & NewNameDWG
'If MyPathConfDWG = "" Then MsgBox "Save As DWG cancelled by user.", vbInformation: End
' Determine if directory exists
Set fso = CreateObject("Scripting.FileSystemObject")
If (Not fso.FolderExists(MyPathPDF)) Then MsgBox (MyPathPDF + " does not exist!"), vbCritical: End
'If (Not fso.FolderExists(MyPathDWG)) Then MsgBox (MyPathDWG + " does not exist!"), vbCritical: End
' PDF Creation
swFrame.SetStatusBarText "Saving files"
MBpdf = swExportPDFData.SetSheets(swExportData_ExportAllSheets, varSheetName)
MBpdf = swModelDocExt.SaveAs(MyPathPDF & "\" & NewNamePDF, 0, 0, swExportPDFData, Errs, Warnings)
'MBpdf = Model.SaveAs4(MyPathConfPDF & "\" & NewNamePDF, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Errs, Warnings)
' DWG Creation
'varSheetName = Model.GetSheetNames
'For i = 0 To UBound(varSheetName)
'MBdwg = Model.ActivateSheet(varSheetName(i))
'NewNameDWG = ModName & "_" & varSheetName(i) & ".dwg"
'MBdwg = Model.SaveAs4(MyPathDWG & "\" & NewNameDWG, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Errs, Warnings)
'Debug.Assert MBdwg
'Next i
' Switch back to first sheet
'MBdwg = Model.ActivateSheet(varSheetName(0))
' Warnings to user on Error
' MsgBox "Errors: " & Errs & vbCrLf & "Warnings: " & Warnings
If Warnings <> 0 Then
swFrame.SetStatusBarText "Warnings during save"
MsgBox "There were warnings. File creation may have failed. Verify" & Chr(13) & "results and check possible causes.", vbExclamation
Else
End If
If MBpdf = False Then
swFrame.SetStatusBarText "Save failure"
MsgBox "PDF creation has failed! Check Add-ins (if S/W 2005 or older)," & Chr(13) & "available disk space or other possible causes.", vbCritical
Else
End If
'If MBdwg = False Then
'swFrame.SetStatusBarText "Save failure"
'MsgBox "DWG creation has failed!" & Chr(13) & "Check available disk space or other possible causes.", vbCritical
'Else
'End If
Call last
End Sub
Sub last()
swFrame.SetStatusBarText "Done"
' Clear immediate values
Set Model = Nothing
Set MyPathPDF = Nothing
'Set MyPathDWG = Nothing
Set swFrame = Nothing
Set fso = Nothing
End
End Sub
