The domain is small yacht building. The tee joint is hull bulkhead joint. The hull and bulkhead are epoxy/fiberglass/linear PVC. Infused or at least vacuum. Marine rules allow me to correctly size hull plating and bulkheads. But are very short of hull bulkhead joint.
Current "rule of thumb" methods use charged epoxy fillet with tape reinforcing. Fillet radius is a function of bulkhead core thickness, and tape fiberglass weigth is 1.5 time bulkhead skin fiberglass weigth.
But it is a very time consuming operation.
So my questions are:
Are there better methods for sizing the fillet ? if a bigger fillet could save me all tape, or even one layer of tape.
Are there better joint methods that can save time ? heard of triangular foam fillets, but got nothing on sizing this.
Are there book for current cored composite structural design for 'dummies' ? I would prefer an engineering workbook than a do-it-yourself boatbuilding with very raw and crude assumptions.
NB : hull/ bulkhead junction is a big thing. a bulkhead is typically 7" * 10" (2m * 3m). The tee joint is not right angle. It may vary from near 90° in the bottom to less than 70 ° on topsides. Hull is all round from evrywhere, so it is very hard to have hull bulkhead gap less than 1/4' (5mm). Better count on a gap between from 0 to 1/2' (10mm).
